• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Member
    sgatzo
    Strange Results UZ
    302 Views, 6 Replies
    12-20-2011 04:19 AM
    During my undregraduate disertation in Aristotle University of Thessaloniki, I work on Educational RSA on a column loss case of steel building. Although my model seems to be rational as far as the rest of the results are concerned, the UZ displacement of the node (128) above the lost column  during non linear plastic analysis appears to be paradox. In detail the displacement for dead load case 1 (SW) are bigger than the respective for the G+0,3Q combination. I attach my file and photos of the results. What would  you propose to me?
    Thank you in advance
    PS: Only one beam has plastic properties (132)
    university email : sgatgog@civil.auth.gr
    Please use plain text.
    Product Support
    Re: Strange Results UZ
    12-20-2011 05:57 AM in reply to: sgatzo
    It seems you have attached dxf file instead of rtd.
    PLease attach robot file
    Rafal Gaweda
    Product Support
    Member
    sgatzo
    12-24-2011 02:56 AM in reply to: RG_Adsk
    Product Support
    Artur.Kosakowski
    12-28-2011 03:39 AM in reply to: sgatzo
    My assumption is that you ignored the lack of convergence warning displayed in v.2011 and checked the results obtained for divergent non linear analysis which couldn't have been be correct. Please use v.2012 instead where the analysis converges.
    I'm attaching the values from v.2012.
    Artur Kosakowski
    Support Specialist
    Product Support
    Member
    sgatzo
    01-17-2012 03:05 AM in reply to: sgatzo
    Hi.
    I have downloaded autodesk robot 2012 an still my non linear analysis does not converge even though it does in my partners pc wiht the exact same file.
    Product Support
    Artur.Kosakowski
    01-17-2012 03:20 AM in reply to: sgatzo
    Please make sure that the same versions are installed on both computers.
    You can find the updates under the following link:
    http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
    Artur Kosakowski
    Support Specialist
    Product Support
    Product Support
    01-17-2012 04:59 AM in reply to: sgatzo
    Turn Kinematic Constrains OFF
    Rafal Gaweda
    Product Support
