• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Contributor
    jo2ny
    Accepted Solution
    Steel vs. Aluminium design
    144 Views, 4 Replies
    02-17-2012 12:14 AM
    Hi all,
    I'm having trouble designing a beam made of aluminium.
    The beam in 5.02 m long, has two pinned suppports, several forces (KN/m - linear distribution) and a few combinations. Calculation is to be made in 2D XZ plane. Everything is ok so far. Calculation and diagrams look ok, but when i perform the steel/alum design i have a problem.
    It seams that if the material is steel, the design verification is correct, but when i change the material to Alum, I get the internal axial value NEd = 0 and no buckling verification.
    I'm probably doing something wrong....
    Attached a picture and the rtd file.
    Also I would like to ask what are the the values underlined with green in the picture. some coordinates?
    Product Support
    Artur.Kosakowski
    Re: Steel vs. Aluminium design
    02-17-2012 02:14 AM in reply to: jo2ny
    Position of the verification point where the ratio is the highest.
    Tension force in bar.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    jo2ny
    02-17-2012 04:03 AM in reply to: Artur.Kosakowski
    Got it,
    Thank you very much!
    Участник
    02-17-2012 05:07 AM in reply to: jo2ny
    Strange no one mentioned that aluminium member should be verified according to EN 1999-1-1 rules not EN 1993-1-1, which, the last time I checked, not implemented in Robot
    Product Support
    Artur.Kosakowski
    02-17-2012 05:14 AM in reply to: Участник
    Can be if sombody decides to run such check in Robot (possibility rather than being told to do this) :smileywink:
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
