• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Contributor
    Accepted Solution
    Steel design
    216 Views, 1 Replies
    02-21-2012 08:03 AM
    When i am designing steel members i am selecting more points along the member (see picture) but in the design results i can see the results only for extreme point .  Is it possible to see the results for other points? Thanks in advance.
    Product Support
    Artur.Kosakowski
    Re: Steel design
    02-21-2012 08:07 AM in reply to: ZHUKOV_ING
    It is not possible to see the results in several points at the same time but you can 'force' Robot to run verification in the selected point only.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
