• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    pevelor
    Steel design - warning messages and fire protection
    116 Views, 3 Replies
    02-17-2012 04:00 AM
    Hi
    I am currently performing steel design.
    My steel columns (18to21) sections have dimensions 100x100x8 and steel beams (22to23) have section 80x80x6,3.
    Why do I get the following warning regarding wall thickness when none of my sections are that thin?
    What's the reason for the elastic warning? (if I turn it of, I don't get the warning)
    In addition, my steel sections will be protected with fire coating/paint. Do I have to define a new material or can I use a existing one (if so, which one)?
    Thanks in advance
    Regards
    Peder
    Product Support
    Artur.Kosakowski
    Re: Steel design - warning messages and fire protection
    02-17-2012 04:13 AM in reply to: pevelor
    Could you send the model (you can leave only the part with these bars) please?
    My assumption is that you used the option described here:
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/How-can-i-change-Robot-from-using-Wpl-to-Wel...
    I'm afraid this is going to be your decision. I'm not in the position to tell you what parameters you should decide on.
    Artur Kosakowski
    Support Specialist
    Product Support
    pevelor
    02-17-2012 04:45 AM in reply to: Artur.Kosakowski
    thanks Arthur
    I cant seem to be able to compress the file enough this time, even without results
    Please refer to the followin thread which has the same model: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Structure-verification/td-p/3334637 -  Ole Deviks vei 6.zip 246 KB
    Product Support
    Artur.Kosakowski
    02-17-2012 07:02 AM in reply to: pevelor
    I don't get any similar warning running the file you indicated.
    Artur Kosakowski
    Support Specialist
    Product Support
