• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    Steel anchor in concrete - contact
    180 Views, 1 Replies
    09-07-2012 06:22 AM
    Hello. I am trying to model a concrete block with cast-in steel anchors However, I wanted to "remove contact" between the steel bars and surrounding concrete. To do this, I followed the following steps:
    1. Model concrete blocks around the anchor (objects---70x70mm rectangle--extrude to appropriate height)
    2. Model bigger concrete block in which all anchors will be cast in (contour --panel (face) -- extrude)
    3. Removed (1) from (2) by object combinations to create voids in the concrete (edit solids and faces - object combinations - subtraction (A-B)
    4. Mesh generation
    5. Creating bars (64mm diameter) within each void
    6. Adding loads and analysing the structure.
    However, I keep getting error messages "Separate structure. Do you want to continue?" and "Distorted element".
    Please see attached model. I would be grateful for any advice on how to model this steel-concrete interface. I understand that robot doesn't have contact elements but is there any workaround for that?
    Please use plain text.
    Product Support
    Re: Steel anchor in concrete - contact
    09-25-2012 04:32 AM in reply to: MokshdaB
    Sorry for getting to you so late.
    Two example files attached.
    Movie how to create it properly "with contact" :
    http://screencast.com/t/MaXqMlkGc
    Movie how to create it properly "without contact" (in this example top nodes of bars will be connected to solid):
    http://screencast.com/t/l1R4stQI6YR
    Rafal Gaweda
    Product Support
