Spring / Damper within ROBOT model
I am looking into modelling a truss structure on brackets. Between the brackets and the truss structure there are elastomeric bearings.
Is it possible to model these bearings within ROBOT for a spectral analysis? Can I represent them with an element and specify their stiffness and damping?
Thank you for your help.
Stuart
Artur.Kosakowski
Autodesk Support
Autodesk Support
No as the modal analysis calculates undamped vibrations only. This would be possible for THA analysis only.
Artur Kosakowski
How I can model a damper (buckling restrained braced frame) on RSA?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Tuned-Mass-Damper-TMD-creation-with-RSA/m-p/...
Artur Kosakowski
