Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Spreadshee t Calculator 2012 - EVar function
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I try to make example from manual:
But expression =EVar(_q*_L^2/8) returns 0. This function works only in this form: =EVar(_q)*EVar(_L)^2/8.
In addition, we have another bug: when I change value of q, for example, value in cell with Evar function return 0. Then, if I want to obtain the result, I go to Preferences, change any unit and press OK. In this case, the value will be updated.
Also I attached text file. Thanks.
Re: Spreadshee t Calculator 2012 - EVar function
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
EVar function works for a single registered cell only rather than for the whole expression. It searches for the registered in RESC cell and imports information about unit type converting it to the default unit. For the efficiency it is recommended to use EUToBase(...) function instead of EVar. EUToBase and EUToUser contain in their arguments all necessary information to convert values to the default units and vice versa to the display units.
It has to be remembered that each value in the expression has to be included in this formula so that EVar(-q*_l^2/8) is incorrect and is not supported.
Please try to use the EUToBase method instead.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
=EUToBase(_q;"unit name")*EUToBase(_L;"unit name")^2/8
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can find the list of 'unit names' in 01units.cfg file (see the attached picture). In addition I'm attaching the modified xls.
Artur Kosakowski
Support Specialist
Product Support
