• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    athurD
    Accepted Solution
    Soil pressure
    477 Views, 11 Replies
    07-23-2012 10:42 PM
    You could tutorial video Soil pressure retaining wall.
    retaining wall problem ?????
    Please use plain text.
    Product Support
    Re: Soil pressure
    07-24-2012 02:53 AM in reply to: athurD
    Example here:  http://screencast.com/t/n1x4jDj3k , I have used predefined soils modified, entered only data you gave us.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    athurD
    Re: Soil pressure
    07-24-2012 03:04 AM in reply to: RG_Adsk
    Thanks you. RG_Adsk
    Verry Good.
    athurD
    Re: Soil pressure
    07-25-2012 01:26 AM in reply to: athurD
    Hi. I is prolem. I is attachment Math manual
    athurD
    Re: Soil pressure
    07-25-2012 07:33 AM in reply to: RG_Adsk
    RG_Adsk
    Please help me?
    Product Support
    Re: Soil pressure
    07-25-2012 07:55 AM in reply to: athurD
    http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-6774D010-E6B5-430D-9379-678ECB43245-479.htm
    "Data that specifies the soil work that results from the displacement of a retaining element. The displacement is defined using the rotation element r, which is assumed to be approximately equal to: f/H (wall top displacement / element height). The soil work mode can be determined as:
    - Active pressure Ka -> ρa ≤ ρ < 0
    - Static pressure Ko -> ρ = 0
    - Passive pressure Kp -> 0 < ρ ≤ ρp"
    so specify f/H as -0.406 or 0.406 or calculated f/H
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    athurD
    Re: Soil pressure
    07-25-2012 08:08 AM in reply to: RG_Adsk
    Thanks you.
    But I Comparison of hand and the results of Robot.
    athurD
    Re: Soil pressure
    07-26-2012 08:10 PM in reply to: athurD
    please help me???
    Product Support
    Artur.Kosakowski
    Re: Soil pressure
    07-26-2012 11:59 PM in reply to: athurD
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    athurD
    Re: Soil pressure
    07-28-2012 02:51 AM in reply to: athurD
    Thanks Artur.Kosakowski
    But I not do.
    You can tutorial video?????
    THanks Artur.Kosakowski
