• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Member
    MaxBob
    Accepted Solution
    Slow meshing
    363 Views, 5 Replies
    11-10-2011 07:59 AM
    Problem in the following... On the big problems very slowly meshing separate plates or walls. Not all building entirely, and even separate elements. How it to solve?
    Please use plain text.
    Product Support
    Re: Slow meshing
    11-14-2011 12:33 AM in reply to: MaxBob
    Hello
    Try Meshing options as shown below (settings of greyed out fields are also important )
    If it does not help please share your model or part of your model to check
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Member
    MaxBob
    Re: Slow meshing
    11-15-2011 11:46 AM in reply to: RG_Adsk
    Thanks big for the answer! I will try! Partially I have solved a problem, namely have made model correction. But there was other problem: process of creation of settlement model goes normally, attributes are appointed, loadings are put, but in the end there is a ROBOT lag, and the model as a result isn't created. The model even without loadings isn't created, in the end hangs. What can it be? By the way, the file with geometry occupies 70 Mb.
    Product Support
    Re: Slow meshing
    11-15-2011 10:34 PM in reply to: MaxBob
    Check Private Message
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    Re: Slow meshing
    11-21-2011 01:16 AM in reply to: RG_Adsk
    I think you will get ~500000 FE model so it will be hard to work with it.
    I suggest different approaches:
    * General remark - in your case mesh slabs first, then cores (walls)
    - change meshing parameters to get smaller number of finite elements
    - if you are not interested in slabs results so far (eg designing cores)  use diaphragms instead of meshed panels:
    -  if you are interested in more accurate results on some slabs – mesh only them or mesh them with more refine mesh than other panels
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Member
    MaxBob
    Re: Slow meshing
    12-05-2011 11:36 AM in reply to: RG_Adsk
    With your help has understood this question :smileyhappy: Thanks!
