Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Slow meshing
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Problem in the following... On the big problems very slowly meshing separate plates or walls. Not all building entirely, and even separate elements. How it to solve?
Re: Slow meshing
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
Try Meshing options as shown below (settings of greyed out fields are also important )
If it does not help please share your model or part of your model to check
Rafal Gaweda
Product Support
Re: Slow meshing
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks big for the answer! I will try! Partially I have solved a problem, namely have made model correction. But there was other problem: process of creation of settlement model goes normally, attributes are appointed, loadings are put, but in the end there is a ROBOT lag, and the model as a result isn't created. The model even without loadings isn't created, in the end hangs. What can it be? By the way, the file with geometry occupies 70 Mb.
Re: Slow meshing
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Check Private Message
Rafal Gaweda
Product Support
Re: Slow meshing
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think you will get ~500000 FE model so it will be hard to work with it.
I suggest different approaches:
* General remark - in your case mesh slabs first, then cores (walls)
- change meshing parameters to get smaller number of finite elements
- if you are not interested in slabs results so far (eg designing cores) use diaphragms instead of meshed panels:
- if you are interested in more accurate results on some slabs – mesh only them or mesh them with more refine mesh than other panels
Rafal Gaweda
Product Support
Re: Slow meshing
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
With your help has understood this question
Thanks!
