Slab
Slab
andrea_pontiggia
Message 1 of 9
Slab
andrea_pontiggia
I can not access the real form of armor plates. What is the exact procedure? thanks
Andrea
Replies (8)
Message 2 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
After calculating the required reinforcement select the panel and press the indicated icon.
Artur Kosakowski
Message 3 of 9
hello all
I don't design for slab in this example " my file: http://www.mediafire.com/?tpxnn81rkzh6x20 "
Please help me and guide for me steps design slab ???
thank pro
mail: duchoatla@gmail.com
Message 4 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
As far as I can see you managed to generate provided reinforcement. In case you want to have bars rather than wire fabrics follow the steps shown on the 2nd picture.
Artur Kosakowski
Message 5 of 9
thanks pro
I'm learning robot althought i don't book for robot
pleasee pro sent me a book robot
hi thank pro very much
mail of me: duchoatla@gmail.com
Message 7 of 9
THANK Pro
when i get a trouble prolem i want you help me
thank y so much
Message 8 of 9
ok thank pro
 I have a question: why selec bars in tab general on step2?
thank pro
Message 9 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
If you want to use wire fabrics you do not need to do this. This is only to generate reinforcement with reinforcement bars rather than wire fabrics. The decision which option to use is in your hands Smiley Happy
Artur Kosakowski
