• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    pevelor
    Slab reinforcement
    349 Views, 5 Replies
    08-03-2012 02:25 AM
    Hi.
    I have a plate with some depressions. I have modelled these depressions as seperate plates with the correct thickness (100mm). In these areas, I only have space for one layer of reinforcement, and I am forced to choose the option "compression/tension" to be able to use membrane reinforcement.
    How will this effect my results, and is there a smarter way of analizing this?
    Kind regards
    Peder
    What are the differenceReinforcement type
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Slab reinforcement
    08-03-2012 03:02 AM in reply to: pevelor
    For slabs you cannot use this option as it disregards bending.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    09-17-2012 11:41 PM in reply to: Artur.Kosakowski
    Hi Artur,
    Will it disregard bending for all slab types i.e. it will only work for columns/beams?
    Can you please expand on that answer? For a floor plate model with shell elements and the reinforcement type is "RC floor" is it not possible to use "bending + compression/tension" as illustrated above?
    Thanks in advance,
    Jesper
    Product Support
    09-18-2012 01:59 AM in reply to: Jesper.Jensen
    Jesper
    This is setting for RC panels only with such reinforcement type assigned
    ?????? More precise question please.
    There are many predefined labels in Robot, you can not edit them. If you want to make any change - just save such label under new name and assign to object(s).
    Rafal Gaweda
    Product Support
    Valued Contributor
    09-18-2012 05:27 PM in reply to: RG_Adsk
    Hi Rafal,
    Thanks for you reply, I'll try to be more clear in this response.
    Arthur mentions above that "For slabs you cannot use this option as it disregards bending.". The option I believe he is talking about is using the option of calculating reinforcement for shells accounting for bending + compression/tension for slabs. My question is then, what type of members can it be used for then?
    If I have a plate model with shell elements and the reinforcement type is "TSL", where "TSL" is a user defined reinforcement type where I have specified using "bending + compression/tension" as illustrated above, is Artur then saying that this will not work as it will disregard bending? That is how I read his reply.
    Jesper
    Product Support
    09-19-2012 03:07 AM in reply to: Jesper.Jensen
    It depens on loads \ forces in panels you want to consider in design. The choice is yours.
    In general:
    - slabs act mostly on bending so you should use "simple bending" ; in case you want to consider axial forces "bending + compression/tension"
    - walls act mostly on compression \ tension so you should use "compression \ tension" (selecting this one is able to set one layer reinforcement in panel) but in case of bending in them use "bending + compression/tension"
    etc
    "For slabs you cannot use this option as it disregards bending."  - I understand this as "bending must be \ should be used for slabs".
    Rafal Gaweda
    Product Support
