• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    joachn09
    Seperate structure error during calculation
    87 Views, 2 Replies
    02-21-2012 08:59 AM
    When I run calculation I get en error saing "Seperate structure, do you want to countinuee?" and "Instability in node 1231 in direction RZ". When I look at the coulumne some of them does not fit properly (but the coordinates are correct), is this the problem mabye?
    Active Member
    joachn09
    Re: Seperate structure error during calculation
    02-21-2012 09:05 AM in reply to: joachn09
    If it is because of the columns is seperate, how do I fix it? the coordinates is correct.
    Product Support
    Artur.Kosakowski
    02-22-2012 12:00 AM in reply to: joachn09
    Try  to switch off display of sections and check if the bars 'meet' in the common nodes. Please look at http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Instability-of-type-2/td-p/3340305 .
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
