• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    New Member
    Orchard_height
    Seimic data input
    503 Views, 3 Replies
    06-06-2011 02:38 PM
    Currently I am working on a Canadian pump station design. I just want to know how to input seismic information based on NBC-2005, and local site soil parameters. The Robot I am working with is Robot Structural Analysis Professional 2011. Thanks
    Please use plain text.
    Valued Contributor
    Bauskas
    Re: Seimic data input
    06-06-2011 10:07 PM in reply to: Orchard_height
    I see that Robot does not have the code you specified embedded.
    Your option is to perfrom spectral analysis based on your code requirements, using raw response spectra from the code.
    Product Support
    Artur.Kosakowski
    Re: Seismic data input
    06-07-2011 12:17 AM in reply to: Orchard_height
    If you set your Preferences as Canadian this code will be set as the default automatically. Otherwise you can easily add it to the current list of the codes and set as the default one in the way shown on the attached picture. Hope this helps.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    Bauskas
    06-07-2011 12:29 AM in reply to: Artur.Kosakowski
    Yep, my fault. It shows the NBC code if switched to the Canadian settings
