Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Scheme for steel plate calculatio n (baseplate and column connection )
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Question about the right scheme for steel plate calculations. Its clear that the most accurate results i will get from 3d scheme/model, but it tooks a lot of time to create the right calculation model in 3d. So I use as a structure type 2d plate or shell design. Now i have some simple questions:
1. How accurate the obtained results if i do it in 2d, not in 3d model?
2. How should i define the loads and supports: anchor bolts as support points and profile contour as a linear load or contrarwise anchorbolts as a point load and profile contour as linear supports? This 2 schemes gives me different results, especially if we have not symmetrical model (take a look to attached picture)
Its all simple and easy if we have axial load Nsd for example, but when column is loaded with a banding moment the load definition as a point loads on anchobolts is still possible (2 points with "+" mark and 2 with "-"), but linear load definition is not so easy in such case, especially if your structure/model is not symmetrical.
Can you give me an advice or some comments about that? Probably there are some more way to calculate such steel base plates...
Thx.
PS 2 simple examples ataached to the mesage, symmetrical and unsymmetrical models.
