• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Member
    STEEL DESIGN - INSTABLE SECTION - SLENDERNESS - Beam design under ULS
    327 Views, 5 Replies
    06-18-2012 02:47 AM
    I have generated 3D frame using RSA 2013 professional. When i verify the rafter beams under ultimate limit state, the results shown are instable. And when optimized under ULTIMATE it provides very large dimension beams. whereas when i used SERVICEABILITY METHOD, it is fine.
    Please help me, how to verify beams in 3D generator.
    Please find attached 3D design file
    Kind regards,
    Ajmal
    Please use plain text.
    Member
    Re: 3D Frame Generator- Beam design under ULS
    06-18-2012 02:49 AM in reply to: zameerajmal
    I ain't able to attach rsa file, please help me
    find result snaps for reference
    why can't i design beam under ULS
    Product Support
    Artur.Kosakowski
    06-18-2012 03:06 AM in reply to: zameerajmal
    ULS and SLS check are two different verifications,. As far as I can see the problem you have got is the exceeded slenderness limit. Looking at the buckling Z part you can see that unrestrained buckling length for 140 section is over 14m which way  too long weak the axes if this section. Have you set the buckling parameters correctly?
    Artur Kosakowski
    Support Specialist
    Product Support
    Member
    Re: STEEL DESIGN - INSTABLE SECTION - SLENDERNESS - Beam design under ULS
    06-18-2012 03:14 AM in reply to: zameerajmal
    I haven't set the paramters. I am a learner, student. how to set, will you please help me
    Ajmal
    Member
    06-18-2012 03:16 AM in reply to: Artur.Kosakowski
    The beam length is 7.11 m
    bay width is 14 m
    Product Support
    Artur.Kosakowski
    06-18-2012 03:20 AM in reply to: zameerajmal
    Assuming it is a 2 span beam then either you set buckling Z (and LTB) coefficients as 0.5L or you should define an intermediate restrain at this point and then set these coefficients as 1.0L  for each of the spans.
    Artur Kosakowski
    Support Specialist
    Product Support
