• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    bjur
    Running calculations on single load case or single combination
    221 Views, 5 Replies
    05-29-2012 04:08 PM
    I have around 35 different load types defined in my model.   I have another 150 load combinations.  I would like to run selected load cases or combinations to check the model with out having to wait hours for it to run the whole list.  I though about saving it to a seperate file and deleting everything I don't want, but there has to be another way.  Is there a way I can run a single load case or combination?  If this is not a feature or there's no reasonable work around, I'd like to add it to the wish list.
    Please use plain text.
    stroxy
    Re: Running calculations on single load case or single combination
    05-29-2012 06:46 PM in reply to: bjur
    I beleive you can assign an auxiliary case parameter to the cases you do not wish to run.
    bjur
    05-29-2012 07:01 PM in reply to: stroxy
    This is handy for running large amounts of load combinations when I don't really want to see the individual load case results...that said, it doesn't help me out here.  What I was really looking for was a way to just run one or two load cases or one or two load combo's from my whole list of cases and combos.  I just want to make sure my non-linear model will run and give accurate results before I let it run all night.
    Product Support
    Artur.Kosakowski
    05-30-2012 12:03 AM in reply to: bjur
    I think what Stroxy suggested is the way to go. You can apply the auxiliary flag to a selection of simple load cases and combinations you do not want to run and only these that are not marked in this way will be calculated. All other combinations will be skipped and simple load cases will be used as loads definition only.
    Artur Kosakowski
    Support Specialist
    Product Support
    bjur
    05-30-2012 10:38 PM in reply to: Artur.Kosakowski
    Certain types of analysis can't be skipped though.  For example Modal analysis can't be skipped or set to auxillary.  This will work though.  Thanks.
    Product Support
    05-30-2012 11:52 PM in reply to: bjur
    Try this:
    Rafal Gaweda
    Product Support
