• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Athi_uk
    Robot Steel Frame analysis
    404 Views, 3 Replies
    10-21-2011 02:33 AM
    Recently I have done a steel frame analysis in Robot 2011 and Can you please answer the following questions:
    1. what is the default connections in Robot among the beams or beams and columns in a 3D frame?
    2. Is it a rigid or pinned connection?
    3. If I apply a pinned-pinned release among the bars structure becomes unstable during the calculation, how can I solve this issue?
    4. Do we need to apply pinned-pinned releases among the bars when we do a frame analysis?
    Many thanks
    James
    Please use plain text.
    Product Support
    Re: Robot Steel Frame analysis
    10-21-2011 02:47 AM in reply to: Athi_uk
    Hi
    As a default all connections between bars are fixed.
    In case of instabilities please upload model or contact me by Private Message
    Rafal Gaweda
    Product Support
    Athi_uk
    10-21-2011 02:57 AM in reply to: RG_Adsk
    Hi Rafal,
    Thanks for your reply and I have attached the model with this message.
    James
    Product Support
    10-21-2011 07:37 AM in reply to: Athi_uk
    Generally - too many releases (wrongly applied, giving instabilities - in this case errors in model).
    You can not release bars on pinned supports (-> the same dofs released twice).
    My vision of this model attached: fixed supports with released columns, bracings ( 101to108 128to137) as  truss bars, Fixed-Pinned1 releases applied on structure, some relases changed to get rid of instabilities.
    Rafal Gaweda
    Product Support
