Autodesk Robot Structural Analysis
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Robot Steel API
- Highlight
- Email to a Friend
i'm trying to retrieve CodeResults using RobotOM steel API. My code (at the failure lines) goes like this:
IRDimDetailedRes RDmDetRes;
RDmDetRes = (IRDimDetailedRes) RdmAllRes.Get(49); //get a specific bar
IRDimCodeResEC3 RdmCodeRes;
RdmCodeRes = (IRDimCodeResEC3) RDmDetRes.CodeResults;
double MPl = RdmCodeRes.PlastMomStrenMplyrd;
When i run my code I get this error message:
error: Unable to cast COM object of type 'System.__ComObject' to interface type 'RobotOM.IRDimCodeResEC3'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{21F70924-8B6C-470F-A19F-5DC40565936D}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)). (line: 186)
Am i using the wrong Code interface? Do i have to instansiate the codeparams for the specific code before that?
Thanks in advance.
Re: Robot Steel API
- Highlight
- Email to a Friend
Try to use IRDimCodeResE32 interface
Rafal Gaweda
Product Support
Autodesk, Inc.
Re: Robot Steel API
- Highlight
- Email to a Friend
Rafal,
still that interface does not exist. I've also tried updating the com interface (from autodesks support page/COM hotfix)
but no change...
Re: Robot Steel API
- Highlight
- Email to a Friend
Send me the whole code
Rafal Gaweda
Product Support
Autodesk, Inc.
Re: Robot Steel API
- Highlight
- Email to a Friend
// new object Robot application
RobotApplication robApp;
robApp = new RobotApplicationClass();
robApp.Interactive = 1;
if (robApp.Project.IsActive == 0)
System.Windows.Forms.MessageBox.Show("ERROR : Open an instance of Robot with the Model you would like to Design");
return;
// Dim robapp As IRobotStructure
IRobotStructure str;
str = robApp.Project.Structure;
int res = robApp.Project.Structure.Results.Available;
if (res == 0){
RobotCalcEngine CalcEngine; //
CalcEngine = robApp.Project.CalcEngine; // Calculation Engine
CalcEngine.Calculate(); // Run Calculations
IRDimServer server = (IRDimServer) robApp.Kernel.GetExtension("RDimServer");
server.Mode = IRDimServerMode.I_DSM_STEEL;
IRDimCalcEngine RDMEngine;
RDMEngine = server.CalculEngine;
IRDimCalcParam RDmCalPar;
IRDimCalcConf RDmCalCnf;
RDmCalPar = RDMEngine.GetCalcParam();
RDmCalCnf = RDMEngine.GetCalcConf();
RDimStream RdmStream; //Data stream for setting parameters
RdmStream = server.Connection.GetStream();
RdmStream.Clear();
//Calculate results for all sections
RdmStream.WriteText("all");
RDmCalPar.SetObjsList(IRDimCalcParamVerifType.I_DC
RDmCalPar.SetLimitState(IRDimCalcParamLimitStateTy
RdmStream.Clear();
RdmStream.WriteText("9"); //Set Load Case
RDmCalPar.SetLoadsList(RdmStream);
RDMEngine.SetCalcConf(RDmCalCnf);
RDMEngine.SetCalcParam(RDmCalPar);
RDMEngine.Solve(null); //Solve Calculations for defined members
IRDimAllRes RdmAllRes;
IRDimDetailedRes RdmDetRes;
RdmAllRes = RDMEngine.Results();
//IRDimCodeResEC3
IRDimCodeResE32 RdmCodeRes;
RdmCodeRes = (IRDimCodeResE32) RDmDetRes.CodeResults;
double Mply = RdmCodeRes.PlastMomStrenMplyrd;
Re: Robot Steel API
- Highlight
- Email to a Friend
What is the code set in Job Prefereces?
It should be ENV 1993-1-2005/AC:2009
One more hint: check whether the results for selected bar exist (not null)
Rafal Gaweda
Product Support
Autodesk, Inc.
Re: Robot Steel API
- Highlight
- Email to a Friend
Rafal,
i'm using that code and that i'm calculating design resluts for all the bars. Could you please send me the list of parent interfaces used in the API for Eurocode design codes? Or does IRDimEurocodeE32 superseeds all the previous eurocode interfaces?
Re: Robot Steel API
- Highlight
- Email to a Friend
IRDimCodeResEC3 - old eurocode
IRDimCodeResEC32 - new one and all NADs. You should be able to get results for all NADs but setting some country specific data for calculations may not be possible.
There are also interfaces for PN, ASD, CM66 codes in Robot.
Rafal Gaweda
Product Support
Autodesk, Inc.
