• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    samuel.pereira
    Robot Steel API - Member definition parameters
    205 Views, 7 Replies
    06-19-2012 04:30 AM
    I'm trying to define members parameters, using Robot Steel API, to design a bar structure steel with EN1993-1.
    I have seen the document "Robot API Steel Design" but I can’t do it. It’s possible provide a complete example to "Visual Basic -Microsoft Excel" for a “Bar” type?
    Please use plain text.
    Product Support
    Re: Robot Steel API - Member definition parameters
    06-19-2012 05:26 AM in reply to: samuel.pereira
    Look closer at paragraphs 4.4.1 and 4.4.2 in mentioned doc.
    Examlpe below
    Set all \ required RDimMembParams in place where you cae see commented dots in code below
    Dim RobApp As RobotApplication
    Set RobApp = New RobotApplication
        RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "ENV 1993-1:1992"
        Dim RLabel As IRobotLabel
        Dim RdimLabelData  As IRDimMembDefData
        Dim RDimMembParams As IRDimMembParamsEC3
            Set RLabel = RobApp.Project.Structure.Labels.Create(I_LT_MEMBER_TYPE, "My Label")
            Set RdimLabelData = RLabel.Data
            RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Y, 100
            RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Z, 200
            RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_X, 300
            RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_Y, 400
            Set RDimMembParams = RdimLabelData.CodeParams
            RDimMembParams.BuckLengthCoeffY = 10
            RdimLabelData.CodeParams = RDimMembParams
            RobApp.Project.Structure.Labels.Store RLabel
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    samuel.pereira
    06-19-2012 06:17 AM in reply to: samuel.pereira
    Thank you!
    samuel.pereira
    06-19-2012 06:50 AM in reply to: RG_Adsk
    When I run the Macro in Excel, it return an error:
    Run-time '13'
    Type mismatch
    It occurs on line:
    Annex image with the error.
    Thank you!
    Product Support
    06-19-2012 07:05 AM in reply to: samuel.pereira
    Wrong Params.
        RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "ENV 1993-1:2005"
        Dim RDimMembParams As IRDimMembParamsE32
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    samuel.pereira
    06-19-2012 07:16 AM in reply to: RG_Adsk
    Ok! Already works! Thank you!
    samuel.pereira
    06-19-2012 09:29 AM in reply to: samuel.pereira
    At the moment, I have defined the member type. What remains now is to assign the type of member to the respective bar, in other words, assign the type "My Label" to a bar 1 and 2, for example. How do this? You can send an example?
    Thank you.
    Product Support
    06-20-2012 04:24 AM in reply to: samuel.pereira
    Like for all labels
    for one \ given bar number
    Dim Rbar As RobotBar
    Dim BarCollection As RobotBarCollection
    RobApp.Project.Structure.Bars.Get(bar_number).SetLabel I_LT_MEMBER_TYPE, "My Label"
    'or
    Set Rbar = RobApp.Project.Structure.Bars.Get(bar_number)
    Rbar.SetLabel I_LT_MEMBER_TYPE, "My Label"
    for bar collection
    Set RobotBarCollection = .........
    For i = 1 To BarCollection.Count
    BarCollection.Get(i).SetLabel I_LT_MEMBER_TYPE, "My Label"
    Next i
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
