• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Contributor
    Accepted Solution
    Robot API - how to modify units
    319 Views, 9 Replies
    12-15-2012 02:53 PM
    I would like to change default units for forces with Robot API, and set N instead of kN.
    Here is my script :
    Dim projPref As RobotProjectPreferences
    projPref = Robot.Project.Preferences
    projPref.Units.Set(IRobotUnitType.I_UT_FORCE, N)
    The last line does not work (red part).
    What is the appropriate syntax to set the unit to Newtons ?
    Please use plain text.
    Product Support
    Re: Robot API - how to modify units
    12-17-2012 02:43 AM in reply to: guillaumeniel
    Dim Robot As New RobotApplication
    Set projPref = Robot.Project.Preferences
    Dim RU As RobotUnitData
    Set RU = projPref.Units.Get(I_UT_FORCE)
    RU.E = False
    RU.Name = "N"
    RU.Precision = 2
    projPref.Units.Set I_UT_FORCE, RU
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    12-17-2012 12:50 PM in reply to: RG_Adsk
    Thanks.
    Active Contributor
    12-17-2012 01:02 PM in reply to: RG_Adsk
    It works for forces, but it does not work for moments. Here is my code :
    RU = projPref.Units.Get(IRobotUnitType.I_UT_FORCE)
    RU.E = False
    RU.Name = "daN"
    RU.Precision = 2
    projPref.Units.Set(IRobotUnitType.I_UT_FORCE, RU)
    RU = Nothing
    RU = projPref.Units.Get(IRobotUnitType.I_UT_MOMENT)
    RU.E = False
    RU.Name = "daN*m"
    RU.Precision = 2
    projPref.Units.Set(IRobotUnitType.I_UT_MOMENT, RU)
    I don't get any error message, but it does not work for moment, whereas it works for forces.
    Product Support
    12-18-2012 02:23 AM in reply to: guillaumeniel
    Dim RUCD As RobotUnitComplexData
    Set RUCD = projPref.Units.Get(I_UT_MOMENT)
    RUCD.E = False
    RUCD.Name = "daN"
    RUCD.Name2 = "m"
    RUCD.Precision = 2
    projPref.Units.Set I_UT_MOMENT, RUCD
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    12-18-2012 01:10 PM in reply to: RG_Adsk
    Thanks.
    Active Contributor
    12-21-2012 02:21 PM in reply to: RG_Adsk
    Sorry to come back again to this topic which appears as solved, but there is still a problem with units in my script. In Robot, if I go to Tools>Project Preferences>Units>Force, I can see that kN changed to daN, as I wanted.
    The problem is that when I calculate and then display the forces array (Results>Forces), forces are still in kN in the array. So I have to go to  Tools>Project Preferences>Units>Force and quit, and then the array is updated and forces appear in daN.
    So there is a kind of "refresh" problem for units.
    Same problem if I want to diplay forces diagrams. Unless I open Tools>Project Preferences>Units>Force, forces are still in kN.
    How can I fix this ?
    Product Support
    12-23-2012 11:32 PM in reply to: guillaumeniel
    That's interesting, we have to check it.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    01-13-2013 06:01 AM in reply to: RG_Adsk
    Any answer to my problem ?
    Product Support
    Artur.Kosakowski
    01-13-2013 11:17 PM in reply to: guillaumeniel
    It will not be possible for us to investigate this situation before the next week.
    Try to add projPref.Units.Refresh at the end of your code.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
