• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Robot-API BeamsColor
    191 Views, 3 Replies
    09-25-2012 04:38 AM
    I used  IRobotView2 to see a structure.
    The application goes through every level,then for each level identifies and tests each beam.
    how to color the ( current ) beam to be  tested.
    Thanks.
    Please use plain text.
    Product Support
    Re: Robot-API BeamsColor
    09-25-2012 05:02 AM in reply to: medtayeb
    Make selection ? Should be in red.
    Rafal Gaweda
    Product Support
    09-25-2012 07:29 AM in reply to: medtayeb
    Hi
    I tried that but no selection appears on  view    ( IRobotView2 MyStrView )
    IRobotSelection MyBarSelected = MyStrView.Selection.Get(IRobotObjectType.I_OT_BAR);
    for (num_bar = 1; num_bar <= MyBarSelected.Count; num_bar++)
                        MyBarSelected.Get(num_bar);
    Many thanks for help.
    Product Support
    10-11-2012 12:53 AM in reply to: medtayeb
    example code :
    Dim sObj As RobotSelection
    Set sObj = RobApp.Project.Structure.Selections.Get(I_OT_BAR) Dim sObj1 As RobotSelection Set sObj1 = RobApp.Project.Structure.Selections.Create(I_OT_BAR) If ((Not sObj Is Nothing) And (Not sObj1 Is Nothing)) Then sObj1.FromText ("3") sObj.Add sObj1 End If
    Rafal Gaweda
    Product Support
