Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Robot 2012-Sprea dSheet Calculator 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I installed Microsoft Office and Robot Structural Analysis on Windows 7 64x. When I run Robot 2012-SpreadSheet Calculator 2012 gives this error:"Compile error. Method or data member not found". How do you think I could solve this problem?
Re: Robot 2012-Sprea dSheet Calculator 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I guess you are using Microsoft Office 2010 64-bit.
Unfortunately 64-bit version of MS Excel is not suported by Robot Extensions - Spreadsheet Calculator.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have installed both RSA pro 2011 x32 and RSA pro 2012 x64 (so they are installed in different directories... Program files (x86) and Program files)
1) Spreadsheet calculator works under RSA pro 2011 but it doesn't work with RSA pro 2012 x64. In particular I can't have any link to RSA 2012 and I got the following info-error " Autodesk Robot Structural Analysis is not running ". Any ideas to link Spr.Calc to RSA 2012?
2) I see some interesting spreadsheet files for EC3 in the library but they seem to be not accessible (see attachment). Why?
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
ad 1)
It seems that automatic un-registering of 32-bit version and registering of 64-bit version did not succeed so it is necessary to do it "manually".
It can be done for instance opening Commnad Prompt as administrator (see the attached screen capture) and running:
"C:\Program Files (x86)\Autodesk\Autodesk Robot Structural Analysis 2011\SYSTEM\EXE\robot.EXE" /unRegServer
to unregister version 2011and then running:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\System\Exe\robot.EXE" /RegServer
to register version 2012
If one of above commands is copied to the clipboard it is enough to click right mouse button in Command Prompt window to paste it to the command line.
Above description is related to English Win 7 with default installation folders.
If it won't help please give more details - which spreadsheet, description of actions and messages.
ad 2)
Spreadsheets with gray icons correspond to spreadsheets which were planned to be implemented but implementation not completed yet![]()
Pawel Pulak
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It seems to work ![]()
thanks Pawel!
ps: of course, in my case, the word "Professional" needs to be added also at the first command.
