• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    FEPI
    Rigid or semi-rigid diaphragms?
    924 Views, 4 Replies
    10-20-2011 01:47 AM
    Hi, we need some help.
    Usually we analyze this kind of structures. (See a simple model attached, this is just an example, This is NOT a project we are working on).
    This kind of structures consist on HSQ beams supporting precast concrete slabs, using vertical concrete cores and vertical bracing to resist horizontal forces. This is the only horizontal stability system. The main system consists in rigid diaphragm floors and vertical concrete cores.
    Often our mission consist to deliver:
    1)     Reactions to foundations
    2)     Steel columns and steel HSQ beams dimensions. (We use a specific program to calculate these beams, so we only take the ULS forces diagrams from ROBOT acting on the beams as an input).
    3)     Forces acting on the concrete cores (for the companies working on the precast concrete panels). We don’t dimension any concrete element. (Not concrete slabs, not vertical concrete cores).
    4)     General stability check for the structure. Global displacements, structural behavior, etc.
    We are trying to find the best way to work with ROBOT because is our main calculation software.
    For our models, we use claddings (because it is light, easy to change loads on, no need of shell elements in very large models) and fake bars to simulate the stiffness of the concrete slabs. By doing this we obtain the vertical loads for beams and also the horizontal transfer to the concrete cores, without using shell elements to modeling the floors.
    Questions:
    1)     Do you think that there is a better way to model this rigid floor effect and at the same time loading the beams, using rigid or semi-rigid diaphragms for example?
    2)     Is there a possibility to define a stiffness for a cladding? So we skip the creation of dummy bars. And still we are not using horizontal shell elements.
    3)     Which is the best and easier way to present results on the concrete cores? We have lots of trouble trying to extract results from vertical shell elements.
    Can you help us with this? Maybe give us some examples?
    Best Regards
    Please use plain text.
    Product Support
    Re: Rigid or semi-rigid diaphragms?
    10-20-2011 03:11 AM in reply to: FEPI
    Hi
    If you have not received my e-mail I will post the answer here also in a minute
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    10-20-2011 03:30 AM in reply to: FEPI
    If you want to consider fake beams for applying loads you have to consider them - Geometry \ Additional attributes \ Load Distribution Options
    Diaphragms creates rigid links between nodes so in such case (fake beams not loaded but used as a stiffeness elements) you do not need them.
    Stiffeness for the cladding can be considered only as diaphragms (rigid links). If you want to apply real thickness of panels to claddiings it is possible but it will be considered for selfweight calculation only unless you mesh such claddings (-> Geometry \ Properties \ Panels Calculation Model)
     What do you really need?
     You can present results as for every panel - tables, maps ; as Panel Cuts ; table of Reduced Results ; results for Cores;  Diagrams for Building ; also for walls in Story Table.
    Best Regards
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    New Member
    Robot1985
    10-22-2011 04:49 AM in reply to: RG_Adsk
    I also have this issue on a steel frame building.  I am using Robot 2011.
    I have steel beams supporting a concrete floor.  The design philosophy is that Horizontal forces will be transferred by the concrete slab, while vertical forces are carried by the steel alone with no composite action assumed.   One slight complication is the slabs are inclined, hence the diaphragm is not in the global axis.
    I would like to use panels to:
    a) apply and distribute  horizontal loads to columns (eg. horizontal panel edge load).
    b) lock column nodes together (ie rigid link in x-y direction of panel plane)
    c) transfer vertical loads to steel beams (ideally one way, but .
    However, i do not want the slabs to act in flexure.
    I have tested the various panel calculation models but without much success;
    The flexible diapragms model  appears to work in composite action with  the steelwork, similar to shells.
    The one way slab model was not providing correct distribution of vertical loads to the structure and also appeared to work in  composite action
    I would be grateful for any advice on the best way of modelling this using the panel command.  I have a work around using rigid links and manually calculated beam loads but I think there must be most be an easier way!
    Many thanks
    Product Support
    10-24-2011 01:14 AM in reply to: Robot1985
    Hi
    We hardly see the real phisical behavior of this model, but try this:
    - model slab as shell with one way loads distribution (-> panel calculation model)
    - connection between inclined slab and beams - compatible nodes with proper selection of dofs and correct rotation of compatibilities
    - lack of panel flexure: either by Material Orthotropy with very small thickness (h) and big stiffeness = increase of n1\n2 factor(s) or by user defined orthotropy -> play with Flexure Stiffeness Matrix
    If it is not what you expect please privide any sketch \ real example how this should work \ look like etc.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
