• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Product Support
    Re: [Revit-Robot] How to clean in Revit all Robot data
    06-04-2012 02:26 AM in reply to: RG_Adsk
    Ready for RST 2013.
    It clears all Revit Extensions parameters together with RST-Robot link parameters.
    Copy attached files with folder from zip to
    [c:\ProgramData\Autodesk\Revit\Addins\2013]
    So it should be :
    c:\ProgramData\Autodesk\Revit\Addins\2013\DREXProjectCleaner\DREXProjectCleaner.dll
    c:\ProgramData\Autodesk\Revit\Addins\2013\\DREXProjectCleaner.addin
    Then this module will be available in Add-Ins tab as shown below:
    To run it just press OK on next window
    Rafal Gaweda
    Product Support
    Please use plain text.
    Product Support
    06-04-2012 09:05 AM in reply to: RG_Adsk
    For 2012
    [c:\ProgramData\Autodesk\Revit\Addins\2012]
    So it should be :
    c:\ProgramData\Autodesk\Revit\Addins\2012\DREXProjectCleaner\DREXProjectCleaner.dll
    c:\ProgramData\Autodesk\Revit\Addins\2012\\DREXProjectCleaner.addin
    Rafal Gaweda
    Product Support
    Valued Contributor
    CristianLANCULESCU1367
    06-05-2012 03:20 AM in reply to: CristianLANCULESCU1367
    CristianLANCULESCU1367 wrote:
    I've erased RM_R2R_LinkSessionIdList, RM_R2R_OriginOffset and RM_RSLoads. Now When I export to Robot I get an Error/Warning saying: "Parameter RM_R2R_OrginOffset, RM_R2R_LinkSessionIdList, RM_RSLoads not defined in shared parameters file "C:\Program Files\...\RMParam.txt".
    It doesn't cause any problems, but I'm still curious why this appears.
    Can I do something about that?
    Product Support
    06-05-2012 03:28 AM in reply to: CristianLANCULESCU1367
    I've erased ....
    Have you done it manually or by this addin?
    Rafal Gaweda
    Product Support
    Distinguished Contributor
    06-06-2012 02:03 PM in reply to: RG_Adsk
    Could you consider publishing the source code for this script? I am sure the advanced users would appreciate it.
    Product Support
    06-06-2012 03:35 PM in reply to: PatrickEC
    No, sorry.
    These Addins are developed by ADSK, copyrighted etc.
    Rafal Gaweda
    Product Support
    Valued Contributor
    06-07-2012 04:45 AM in reply to: RG_Adsk
    RG_Adsk wrote:
    I've erased ....
    By hand
    Product Support
    06-07-2012 05:20 AM in reply to: CristianLANCULESCU1367
    Use clear then chek.
    Rafal Gaweda
    Product Support
    05-23-2013 12:51 PM in reply to: RG_Adsk
    I will appreciate a new 2014 version of this plugin.
    05-23-2013 03:19 PM in reply to: PatrickEC
    I am trying to run this on 2013 now and I think it is installed correctly, because it shows up in the External Tools menu. But when I click to run it, it does not seem to be doing anything, there is no message no nothing. And Robot data are still there.
