• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    Reinforcement Designer - Manually modifying input parameters
    306 Views, 9 Replies
    08-12-2012 11:30 PM
    When using the reinforcement designer and calculating required reinforcement for SLS to CP65 this is done limiting the crack width to 0.3mm. If on a specific job I need to do the same calculations, but limit the crack width to 0.25mm, is there a way to do so in Robot?
    Thanks in advance,
    Jesper
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Reinforcement Designer - Manually modifying input parameters
    08-13-2012 12:30 AM in reply to: Jesper.Jensen
    1. Increase unit precision in Job Preferences
    2. Set crack limit
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    08-13-2012 11:25 PM in reply to: Artur.Kosakowski
    Thanks Artur that's great, but how do you bring forward the CP65 Reinforcement Parameter Tab?
    Jesper
    Product Support
    Artur.Kosakowski
    08-14-2012 12:18 AM in reply to: Jesper.Jensen
    I'm afraid that I don't understand the question. Could you rephrase it please? Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    08-15-2012 07:03 PM in reply to: Artur.Kosakowski
    If you open the attachement you made in your first reply, the bottom picture show a tab called "CP65 Reinforcement Parameters" where the crack width can be modified. Can you please let me know how I can access or open that window in Robot?
    Jesper
    Moderator
    Romanich
    08-15-2012 09:27 PM in reply to: Jesper.Jensen
    Hi Jesper,
    Valued Contributor
    09-06-2012 12:30 AM in reply to: Romanich
    Thanks for the previous replies, answers were perfect. I've another question in relation to the crack width calculations I'm hoping you can answer. I assume the crack width is calculated in the location as indicated on the attachment (between the bars at a distance acr) is that correct?
    If I specify a 200mm cover, is there a way I can force Robot to calculate the crack width at a distance 40mm from the outermost bar, and not at the face?
    Jesper
    Product Support
    Artur.Kosakowski
    09-06-2012 01:54 AM in reply to: Jesper.Jensen
    I'm afraid that I don't understand the question. Robot calculates cracks in these locations (s is based on calculated require reinforcement area and declared bar diameter).
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    09-06-2012 05:23 PM in reply to: Artur.Kosakowski
    Yes, that was my assumption as well.
    In the dialog box shown above (4 in red brackets) called "CP65 Reinforcement Parameters" I can define the top/bottom cover under the tab called "Reinforcement".
    If I set the cover to 200mm, is there a way to force Robot to calculate the crack width 40mm away from the reinforcement, instead of at the concrete face 200mm away?
    Jesper
    Product Support
    Artur.Kosakowski
    09-06-2012 11:46 PM in reply to: Jesper.Jensen
    I'm sorry but there is no such possibility.
    Artur Kosakowski
    Support Specialist
    Product Support
