• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Contributor
    Reaction Mismatch - Check Val not equal to Zero
    256 Views, 4 Replies
    05-28-2012 05:18 AM
    In my model the check value in the reactions case is greater than zero - i.e. the sum of the forces is greater than the sum of the reactions by around 7800kN (out of a total sum of forces of 72600kN). i am also getting horizontal reactions with no horizontal forces applied which don't sum to zero, and huge moments about pinned supports.
    I am getting some nodal instabilities as pre-analysis warnings which shouldn't be unstable - all have at least one point of fixity. I also had a couple of nodal instabilities at pinned supports, where i have now used fixed supports to get rid of the instability.
    I can't attach the model file as it is too large - is there another place that i can upload it adn link to?
    Thanks!
    Please use plain text.
    Product Support
    Re: Reaction Mismatch - Check Val not equal to Zero
    05-28-2012 05:28 AM in reply to: PaulGrimes2282
    Try wetransfer.com or filemail.com
    If not I will create ftp for you
    Rafal Gaweda
    Product Support
    Active Contributor
    05-28-2012 09:26 AM in reply to: RG_Adsk
    Product Support
    05-29-2012 02:20 AM in reply to: PaulGrimes2282
    1. Do not use kinematic links.
    2. Use recommended meshing parameters and correct meshes
    Take a look at message 3 in this thread:
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Structure-verification/m-p/3334637/highlight...
    After correcting coherence of meshes I think you should remove releases from columns 952 1424 or define them properly not producing instabilities in model
    COrrected model:  http://wtrns.fr/ospazeccgHWsNg
    Rafal Gaweda
    Product Support
    Active Contributor
    05-30-2012 02:30 AM in reply to: RG_Adsk
    Thank you so much for looking at this - I will have a check through the model ASAP - i'm off on holiday at the end of today, but will try and have a look before i go, otherwise i will have a look when i get back.
    thanks again.
