• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    stroxy
    Raft with Ground Beams
    158 Views, 1 Replies
    12-30-2011 05:30 PM
    Hi
    1. What is the difference between elastic ground bars from the geometry>additional attributes menu and elastic linear support from the geometry supports menu?
    2. If I have a raft with integrated beams, do I assign elastic supports to the raft and then additionaly assign elastic ground bar properties (or elastic linear support) to the beams?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Raft with Ground Beams
    01-01-2012 11:52 PM in reply to: stroxy
    1. The later can be applied to the edges of the panels only.
    2. No, this will 'double' the elasticity along the beams.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
