• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Member
    memoalcr
    RSAPro 2013 load types label id
    173 Views, 1 Replies
    09-04-2012 08:01 AM
    In RSAPro 2013 the structure verification procedure keeps giving the "Duplicated load case label" warning. It seems that the automated numbering for the load type labels is not updating itself properly. In previous versions, I never changed this label manualy. If one creates a dead load, the software gives it a label, say "DL1". If I try to create a different dead load, the label does not update to "DL2" for the new load case - as it did in previous versions. Please advise on what is the correct procedure for avoiding the  "Duplicated load case label" warning without having to manually change the labe id.
    Please use plain text.
    Product Support
    Re: RSAPro 2013 load types label id
    09-05-2012 12:10 AM in reply to: memoalcr
    You can ignore this or change Label in Loads table \ Cases tab.
    If you do use RC Footing Design module to design foundation for supporting node in model  you can see them in calculation note in combination definition
    Rafal Gaweda
    Product Support
