• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    memoalcr
    RSAPro 2012 ANSI/AISC 360-05 Cb Parameter
    280 Views, 2 Replies
    10-11-2011 10:41 AM
    In RSAPro 2012 steel design for ANSI/AISC 360-05; when trying to define the Cb parameter for "Lateral Buckling", the window for selecting the Parameter Cb does not pop-up (see attached file). Is this a software problem or am I missing a design step?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: RSAPro 2012 ANSI/AISC 360-05 Cb Parameter
    10-12-2011 04:37 AM in reply to: memoalcr
    Thank you for indicating this issue. We will investigate it.
    Artur Kosakowski
    Support Specialist
    Product Support
    Product Support
    Artur.Kosakowski
    10-27-2011 12:00 AM in reply to: memoalcr
    Please download and install SP3 for Robot 2012. Mind to select the correct version of the SP (Professional or Standard version as well as 32 or 64-bit OS).
    http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
    Artur Kosakowski
    Support Specialist
    Product Support
