• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    New Member
    admin_biep
    RSA 2012 - PROBLEM WHILE CREATING DEPLOYMENT CONFIGURATION
    159 Views, 2 Replies
    12-20-2011 05:29 AM
    Hi everybody,
    I'm having trouble while creating a deployment configuration. I'd like to add the SDK component to my configuration.
    When in "Installation type" I choose "Custom" there is no "SDK" proposition, so i choose "Standard"
    Then in the "Additionnal Files" field I choose "Addd Folder" or "Add Drive" (the result is the same), i choose "browse" and I go taking the" E:/x86/Tools/RSASDK/RSA_SDK.exe" file in the main folder (For a 32 bits installation)
    I create the file with the ".lnk" extension, and when I lauch it, the setup installation stops ans shut down suddenly.
    Does anyone have this problem? Does anyone have a solution?
    Thanks.
    Please use plain text.
    Product Support
    Re: RSA 2012 - PROBLEM WHILE CREATING DEPLOYMENT CONFIGURATION
    12-20-2011 05:40 AM in reply to: admin_biep
    Truly saying nobody has ever tried SDK installation in deployment.
    SDK in unpacked (just unzip it) version:
    ttp://www.megaupload.com/?d=XM699PPN
    Rafal Gaweda
    Product Support
    New Member
    admin_biep
    12-20-2011 08:12 AM in reply to: RG_Adsk
    Thank you for the link.
    I downloaded it but that doesn't solve my problem because when i'm in the "Additionnal Files" field and I choose "Addd Folder" or "Add Drive" (the result is the same) then i choose "browse" I can only pick a file and not a folder.
    However, i have the same problem with Autocad.
    So my question is: How to add plugins or programs while creating a deployment configuration? Is it possible to add an executable file like "whatever.exe" and it will do the installation?
    Thanks for yout  help.
