• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    kmarcinkiewicz
    Accepted Solution
    ROBOT - Check Values not equal to zero
    258 Views, 5 Replies
    01-12-2012 04:37 AM
    I am creating a model of a glass screen. The stresses in the panel given to me by robot do not match my expectations.
    I found that the reason for that might that the check values are not equal to zero in the reaction table. Is there a way to solve it? (I already remeshed the model and checked all my inputs for errors)
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: ROBOT - Check Values not equal to zero
    01-12-2012 04:43 AM in reply to: kmarcinkiewicz
    The possible reasons can be the fact that reported instability warning was ignored or the use of non linear analysis (then the difference can is some cases be justified). Can we you attach the model and indicate where (which load case) you found this difference please?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    kmarcinkiewicz
    01-12-2012 04:58 AM in reply to: Artur.Kosakowski
    I double checked for that, knowing it might be an issue.
    I have attached the model. The discreptancy occurs in all lateral load cases, I am particularly interested in the combination 1.35Gk+1.5Wk+1.05Qk (PEUTZ).
    Product Support
    Artur.Kosakowski
    01-12-2012 06:08 AM in reply to: kmarcinkiewicz
    Please use Sparse solver (Job Preferences > Structure analysis) for calculations.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    kmarcinkiewicz
    01-12-2012 07:41 AM in reply to: kmarcinkiewicz
    That solved my problem!
    Thank you!
    Product Support
    Artur.Kosakowski
    06-12-2012 06:23 AM in reply to: kmarcinkiewicz
    Correction for the Sparse solver has been done in SP1 for Robot 2013.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
