Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
ROBOT API - RATIO
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm trying to retrieve CodeResults RATIO using Robot steel API, for example from bar number 1. My code (at the failure lines) goes like this:
Sub RATIO()
Dim RobApp As New RobotApplication
Dim RDmEngine As IRDimCalcEngine
Set RDmEngine = RDmEngineServer.CalculEngine
Dim RDmRetValue As IRDimMembCalcRetValue
Dim RDmDetRes As IRDimDetailedRes
Set RDmDetRes = RdmAllRes.Get(1)
RDmRetValue = RDmDetRes.RATIO
Cells(1, 1) = RDmRetValue
End Sub
I have seen the document "Robot API SteelDesign" but it not return the ratio. What am I doing wrong? It can provide a complete example to "Visual Basic -MIcrosoft Excel"?
Re: ROBOT API - RATIO
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sub Ratio()
Dim RobApp As RobotApplication
Set RobApp = New RobotApplication
Dim RDMServer As IRDimServer
Set RDMServer = RobApp.Kernel.GetExtension("RDimServer")
RDMServer.Mode = I_DSM_STEEL
Set RDmEngine = RDMServer.CalculEngine
'the part below is optional, use it if you want to set calculation parameters by the code
Dim RDmCalPar As IRDimCalcParam
Dim RDmCalCnf As IRDimCalcConf
Set RDmCalPar = RDmEngine.GetCalcParam
Set RDmCalCnf = RDmEngine.GetCalcConf
Dim RdmStream As IRDimStream 'Data stream for setting parameters
Set RdmStream = RDMServer.Connection.GetStream
RdmStream.Clear
'Calculate results for all sections
RdmStream.WriteText ("all") ' member(s) selection
RDmCalPar.SetObjsList I_DCPVT_MEMBERS_VERIF, RdmStream 'members verification
RDmCalPar.SetLimitState I_DCPLST_ULTIMATE, 1 'Set Limit State
RdmStream.Clear
RdmStream.WriteText ("1") 'Set Load Case(s)
RDmCalPar.SetLoadsList RdmStream
RDmEngine.SetCalcConf RDmCalCnf
RDmEngine.SetCalcParam RDmCalPar
'end of calclulation parameter settings
RDmEngine.Solve Nothing
Dim RDMAllRes As IRDimAllRes
Set RDMAllRes = RDmEngine.Results
Set RDmDetRes = RDMAllRes.Get(1)
Cells(1, 1) = RDmDetRes.RATIO
End Sub
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Very useful! Thank you very much!
