• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    Robot12
    RESULTS - DISPLACEMENT vs. DEFLECTION - Definitions used by Robot
    1135 Views, 5 Replies
    06-18-2012 01:00 PM
    What are the definitions for deflection and displacement used in Autodesk Robot Structural Analysis ?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Definitions used by Autodesk Robot Structural Analysis
    06-19-2012 12:09 AM in reply to: Robot12
    Which kind of results do you mean exactly? Could you make a screen capture that illustrates what you want to compare please?
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Member
    Robot12
    06-19-2012 03:00 AM in reply to: Artur.Kosakowski
    I don't want to compare any results I just want to know what are the differences between deflection and displacement ? I want definitions for both deflection and displacement used by Autodesk Robot Structural Analysis.
    Thanks.
    Product Support
    Artur.Kosakowski
    06-19-2012 03:16 AM in reply to: Robot12
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Member
    Robot12
    06-19-2012 04:39 AM in reply to: Artur.Kosakowski
    Does this illustration of deflection and displacement apply to a 3D frame ? Is there any sentence that defines deflection and displacement ?
    Thanks.
    Product Support
    Artur.Kosakowski
    06-19-2012 04:44 AM in reply to: Robot12
    Yes, it does. The displacements is the distance from the original position of a point to its final location on the deformed model. The deflection is the distance from the line that links the origin and end nodes of a bar on the deformed model with the position of a point on the deformed model.
    Artur Kosakowski
    Support Specialist
    Product Support
