• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    New Member
    RC deflections
    98 Views, 1 Replies
    06-21-2012 12:03 PM
    Can Robot determine the cracked moment of inertia( second moment of area) of a reinforced concrete section in particular a flat slab. Taking into account the reinforcement and tensile strength of the concrete
    I appreciate that this would require several interations in order to produce the correct results.
    Does it take into account tension stiffening?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: RC deflections
    06-21-2012 11:16 PM in reply to: db210612
    Pease check the stiffness update method (http://forums.autodesk.com/t5/Autodesk-Robot-Structural/elastic-and-nonelastic-slab-deflection-verif...
    The number of iterations is limited to one. The values of the reduction of stifness (inertia) are shown both as maps or in the reinforcement table.
    Artur Kosakowski
    Support Specialist
    Product Support
