• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    JIHADTM
    RC column design
    171 Views, 5 Replies
    10-10-2012 04:54 AM
    I'm designing RC column by using robot based on ACI-code.Also the automatic combination for the structure model are generated based on the same code.However I noticed that after viewing the colum design notes that the design combination is different from the automatic combinations. Can you explain thisplease.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: RC column design
    10-10-2012 05:02 AM in reply to: JIHADTM
    Could you attach the corresponding rtd file and indicate the difference in combinations on a screen capture please?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    JIHADTM
    10-10-2012 05:13 AM in reply to: Artur.Kosakowski
    Please ,find attached documents
    Product Support
    Artur.Kosakowski
    10-10-2012 06:02 AM in reply to: JIHADTM
    Could you send the rtd file too please?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    JIHADTM
    10-10-2012 06:43 AM in reply to: Artur.Kosakowski
    i'm sorry .rtd is not supported. I can submitt it
    Product Support
    Artur.Kosakowski
    10-10-2012 06:49 AM in reply to: JIHADTM
    Compress it (*.zip) and then attach. Should work.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
