• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Product Support
    Re: RC beam/column warnings & pinned linear joint problem
    09-17-2012 05:47 AM in reply to: Opel5
    Opel5 wrote:
    Thanks for the input Rafal :smileyhappy: I've tried releasing "Edge 4" of the panel 459 as "pinned-pinned" but it seems to only release all edges as pinned, and after applying the release there is no was of checking which edge of an object has release conditions. Is it possible to specify only 1 linear edge release at the base of the stairs panel?
    Example
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Please use plain text.
    Product Support
    09-17-2012 06:13 AM in reply to: Opel5
    Scott
    Could you give a bit more guidance please on how I acheive the above please? I had nodes all over the building to start with but a lot of them have been removed during FE meshing, FE mesh removal (for editing), and panel alterations. I have quite a few cases where the wall panels seem to clash with the embedded RC columns and assumed Robot could distinguish between the two rather than having to manually (and painfully) separate panels from columns at all intersections?
    See below.
    Look also at difference between results.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Contributor
    09-25-2012 12:15 AM in reply to: RG_Adsk
    Hi Rafal,
    I've finally got a chance to go back and follow your advice concerning below:
    . In practise the reinforcement will be lapped along edges, so is there a way of releasing the nodal corner only at the wall corner - slab?
    No you can apply linear releases to panels. Divide \ create shorter edge nead the corner and apply there releases
    But can't seem to find a way of neatly dividing a small L-shaped peice of the roof slab panel at the outward wall corner in the attached screenshot to remove the reinforcement spike?
    Product Support
    09-25-2012 08:10 AM in reply to: Opel5
    Scott
    Divide WITH node generation, then select panels edge.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    Artur.Kosakowski
    10-04-2012 06:58 AM in reply to: RG_Adsk
    Scott,
    The procedure as requested.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    10-04-2012 07:25 AM in reply to: Artur.Kosakowski
    Thanks Artur :smileyhappy: Got the hang of the procedure now
