• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    athurD
    Accepted Solution
    RC DESIGN - BUCKLING - Effective Length Factor K (When concrete Frame in ROBOT)
    409 Views, 5 Replies
    06-13-2012 08:59 PM
    Hi. Suport
    Please help me. I want find Effective Length Factor K in robot. THanks
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Effective Length Factor K ( When concrete Frame in ROBOT) ?
    06-13-2012 11:33 PM in reply to: athurD
    See the attached picture.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    athurD
    06-14-2012 02:12 AM in reply to: Artur.Kosakowski
    Thansk. Artur.Kosakowski
    Picture is caculation cloum
     So when caculation Beam, Wall??
    Product Support
    Artur.Kosakowski
    06-14-2012 04:03 AM in reply to: athurD
    The effect of buckling is disregarded for RC Beams design. The RC Wall module is currently not available for SNIP codes
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    athurD
    06-14-2012 04:21 AM in reply to: Artur.Kosakowski
    So when caculation wall code not SNIP. Yes i kown
    But where edit Effective Length Factor K when use code ACI ????
    Thansk
    Product Support
    Artur.Kosakowski
    06-14-2012 05:31 AM in reply to: athurD
    Not available in Robot. I have limited knowledge of ACI code  - does it address this issue directly and if it does which paragraph of the code is it?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
