Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
RC Column verificati on: Design combinatio n EC8
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
1.00SPE_NEW14 (A)( SEIS. Joint X + )
How does one interprete the term of the design combination above, used in RC Column design with seismic dispositions under EC8, particularly the (SEIS. Joint X+) portion?
Re: RC Column verificati on: Design combinatio n EC8
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Any clarifications please?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It means:
from combination 1.00SPE_NEW14
on level (A) - top of column
It is a set of additional forces generated by the analysis of the joint (capacity in beams connected to this node=joint required for the seismic capacity calculations of columns with respect tothe capacity of columns (currently calculated and the top if one exists) - I hope you can understand :-) SEIS. Joint
in direction X
Capacity calculated for positive moment +
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thx Rafal
Can ( SEIS. Joint X + ) be de-activated even with seismic dispositions checked? It seems to cause very high moments in the column. I know it is a requirement of some codes, but would like to be able to see what is required from purely design considerations vis-a-vis capacity design considerations.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The only way is to calculate the column before calculations of beams adjoining to the node above the column. There will be no results from beams so a warning will appear as on jpg below (No. 2 and 3). The rest of seismic analysis should be done.
Rafal Gaweda
Product Support
