• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    Accepted Solution
    RC BEAMS - SNIP - Area steel ?
    321 Views, 9 Replies
    12-21-2012 12:36 AM
    Hi.. I is Prolem
    I use code Snip 2.
    Please use plain text.
    Re: Area steel ?
    12-21-2012 03:39 AM in reply to: A.wikipedia
    Please. I is need. Thak
    Product Support
    Artur.Kosakowski
    Re: Area steel ?
    12-21-2012 04:08 AM in reply to: A.wikipedia
    Here you are.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Re: Area steel ?
    12-21-2012 05:45 AM in reply to: Artur.Kosakowski
    Thanks. Athur
    Re: Area steel ?
    12-24-2012 06:41 AM in reply to: A.wikipedia
    Hi. I is prolem
    Question 1. picture 1
    Conver c of picture right ???
    Question 2. Pticture 2
    Why c=0????
    I attment file picture under.
    thanks
    Product Support
    Artur.Kosakowski
    Re: Area steel ?
    12-27-2012 12:39 AM in reply to: A.wikipedia
    Looking at the rtd file you sent the cover is displayed as 20 mm. Could you sen the rtd file where you have it displayed as 0 mm in the calculation note?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Re: RC BEAMS - SNIP - Area steel ?
    12-27-2012 02:53 AM in reply to: A.wikipedia
    Is here.
    Thanks.
    Product Support
    Artur.Kosakowski
    12-27-2012 03:19 AM in reply to: A.wikipedia
    Thank you for the file. As far s I can see the 0 values are displayed when covers are locked. As you have the reinforcement frozen calculations of the beam will not change it therefore you can unmark these check boxes to have the correct value displayed in the calculation note.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    12-27-2012 03:50 AM in reply to: Artur.Kosakowski
    Thank Artur.
    But If I not Fixed. As (robot) > As( hand).
    Product Support
    Artur.Kosakowski
    12-27-2012 03:57 AM in reply to: A.wikipedia
    1. Calculate beam with the fixed covers
    2. Edit the value of covers in the calculation note or
    2a. Freeze the reinforcement generated for the fixed covers
    2b. Calculate the beam with frozen reinforcement again to have the 20 mm cover displayed in the note.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
