• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    pevelor
    Accepted Solution
    Punching Shear
    357 Views, 1 Replies
    01-03-2012 05:36 AM
    Hi
    I am currently reviewing the effects of altering the thickness of a slab foundation.
    At pile supports, I am interested in cheacking for punching shear. The only information I have found on this topic is as displayed in the link below:
    http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-8E6475AE-CAD9-4A0D-82A0-0B98CBA2D84-1283.htm
    The conditions are not met for 'Contact Surface', and I am unsure of the meaning of this (ref. Attached file).
    My questions are,
    What is the best way to check for punching shear, and to calculate required punching shear reinforcement?
    Sincerely
    Peder
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Punching Shear
    01-03-2012 07:36 AM in reply to: pevelor
    Peder,
    The topic you refer to is for spread footings. Please use this one instead:
    http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-1D2B5447-1C96-454F-A95F-F8B36D118A9-1309.htm
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
