• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    stroxy
    Accepted Solution
    Provided Reinforcement design for divided column
    275 Views, 7 Replies
    09-26-2012 05:23 AM
    How does one design a column which has been divided into two (or more) columns in the analysis module (because of connecting beams mid-height in column, or column spanning multiple stories)  in the RC design module.
    I assume you can take a section and input the real length of the column in the buckling analysis but how does one factor in columns end moments, etc.??
    Please use plain text.
    Product Support
    Re: Provided Reinforcement design for divided column
    09-26-2012 08:33 AM in reply to: stroxy
    You have to divide such column into parts.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    stroxy
    09-26-2012 09:27 PM in reply to: RG_Adsk
    So if I have say a 6m column divided into 2 parts for analysis.  In designing the column I will design both parts as separate columns and enter efffective length  factor * 6m as the buckling length for each part ?
    Product Support
    09-27-2012 08:08 AM in reply to: stroxy
    Decision is yours but IMHO if you are talking about right hand side case (below) I would suggest to use 3m as column length. Left => 6m.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    stroxy
    09-27-2012 08:17 AM in reply to: RG_Adsk
    Thanks Was talking about LHS case
    stroxy
    09-27-2012 08:19 AM in reply to: stroxy
    How did you get buckling shapes to show?
    Product Support
    09-27-2012 08:36 AM in reply to: stroxy
    FEM Buckling analysis
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    stroxy
    09-27-2012 10:18 AM in reply to: RG_Adsk
    Thanks once again!!:smileyvery-happy:
