• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    Provided (Real) Reinforcement Bar Diameter List - How to add new diameter ?
    424 Views, 2 Replies
    12-14-2011 10:40 PM
    Hi All,
    How I can add new diameter to the Bar Diameter List in the Provided (Real) Reinforcement module ?. barre.PNG
    The 25 mm diameter is not used in Italy and 24,26,28,30,32 and 36 mm diameter are missing.
    Any suggestion ?
    Please use plain text.
    Moderator
    Romanich
    Re: Provided (Real) Reinforcement Bar Diameter List - How to add new diameter ?
    12-14-2011 11:06 PM in reply to: GabrieleNovembri1027
    Hi
    You can simply edit xml file with Reinforcement  data. You may use internal tools or, for example, Altova XMLSpy.
    Reinforcement  data are located at c:\ProgramData\Autodesk\Structural\Common Data\2012\Data\Reinf\.
    In Robot make this steps:
    12-15-2011 01:54 AM in reply to: Romanich
    Thanks.
