• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    andrea.pontiggia
    Problem with design combinations
    118 Views, 1 Replies
    01-20-2013 12:15 PM
    I changed some coefficients normally to generate personal combinations. Robot does not generate seismic combinations. Even changing legislation fails to create design combinations. What can I do? thanks
    Andrea
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Problem with design combinations
    01-21-2013 12:57 AM in reply to: andrea.pontiggia
    My assumption is that you  want to generate automatic combinations. PLease check if you have all relations for each nature of loads correctly defined.
    Artur Kosakowski
    Support Specialist
    Product Support
