• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Contributor
    Problem with SpreadSheet Calculator 2013
    215 Views, 2 Replies
    11-15-2012 09:24 PM
    please find enclosed a Robot file plus 2 spreadsheets. We're trying to calculate the joint between bars 2 and 4.
    1st problem :
    We can't load the values from Robot.
    2nd problem :
    When we enter the values by hand, the spreadsheet bugs when changing the angle (alpha), and stops calculating.
    The file called 33SCHM_TIMB_EC5_009_BUG.xls was created after this bug.
    The file called 33SCHM_TIMB_EC5_009.xls was created before it.
    Thanks for your help.
    Rgds
    Benoît
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Problem with SpreadSheet Calculator 2013
    11-16-2012 03:12 AM in reply to: TraitCarré
    We will investigate the import issue you reported (mind that it is required you divide bar 2 into two parts at the location of node 5). For the angle try to use the workaround shown on the attached movie.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    11-16-2012 03:45 AM in reply to: Artur.Kosakowski
    Ok for the angle.
    We've already tried to divide the bar 2, without success.
    benoît
