• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Moderator
    Romanich
    Accepted Solution
    Problem with Russian language - ??? in tables
    158 Views, 6 Replies
    07-02-2012 12:51 AM
    Hi again,
    This problem have common roots with this and this, but in this case problem very serious.
    For example, I have several panels, selected them and copied list "2до6" to the clipboard. After then paste this data for Load table (for example) and obtain this:
    After pressing Enter, only panels 1, 2 and 6 will be loaded. Please, watch the video.
    Please use plain text.
    Product Support
    Re: Problem with Russian language - ??? in tables
    07-03-2012 06:01 AM in reply to: Romanich
    Hi Roman,
    please try to change active keyboard to Russian one:russian_keyb.png
    In my case it helped.
    Nevetheless this effect is under investigation to be explained and corrected :smileyhappy:.
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
    Moderator
    Romanich
    07-03-2012 06:12 AM in reply to: pp2008
    Hi Pawel,
    Your trick is working :smileywink:
    05-15-2013 03:52 AM in reply to: Romanich
    Dear support team,
    Could you provide a proper solution for this issue? "tricks" are not working in our case. Thank you.Russian language.jpg
    05-16-2013 06:11 AM in reply to: vmorkunas
    Guys, could you reply if this is solvable or not so we would not waste any more our time.
    Thank you.
    Product Support
    05-16-2013 06:15 AM in reply to: vmorkunas
    It is not written in which version you observe these effects and the resolution of screen capture makes it difficult to read but I guess this time it is not related to any "tricks" but to standard behaviour of Robot in all versions up to 2013.
    All these versions of Robot are non-Unicode so to correctly display non-Unicode caracters (including Cyrillic ones) it is necessary to select appropriate language in regional settings of Windows:
    Note: after this change Windows is restarted.
    BTW:
    Starting from 2014 release RSA supports Unicode so none of above settings or "tricks" is necessary!
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
    05-16-2013 09:01 AM in reply to: pp2008
    Thanks! it is good to know
