• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Mentor
    tony.ridley
    Accepted Solution
    Prestress Force
    228 Views, 10 Replies
    10-01-2012 05:18 AM
    If I define prestress force for load case 2 (say, additional self weight case), but I do not include load case 2 in the combination will the prestress be ignored?
    Tony
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Prestress Force
    10-01-2012 05:28 AM in reply to: tony.ridley
    Correct.
    It would be included (providing that defined within the first loads case) automatically  for a cable model (assembly load case) or on demand for other model types  when such functionality is activated as shown below:
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Mentor
    tony.ridley
    Re: Prestress Force
    10-01-2012 05:35 AM in reply to: Artur.Kosakowski
    OK thanks a lot!  Thanks for quick answer.
    I have another question relating to the picture you posted now (off topic of prestress)
    The "include case as starting point" feature;
    Is this like saying that for a given non linear case, it will be "built" or superimposed on top of the case typed into the box?
    Example for a lateral wind load case that is having trouble converging, if I add a gravity case to this list it often helps me. Does it not automatically add load case 1 as a starting point for all non linear cases?  Or do i need to add self weight case to this "include case as starting point" box?
    Tony
    Valued Mentor
    tony.ridley
    Re: Prestress Force
    10-01-2012 05:42 AM in reply to: tony.ridley
    Prestress Related Question again.
    When I use the "include case as starting point" feature the so my prestress will be applied to the other non linear cases, will it be "Doubled up" in the combinations?  i.e. added 1000kN in self weight case, then this is starting point for wind and live cases.  WHen it gets tot he combination of dead live and wind will I get the force tripled?
    SOrry i have ot just built a test model to figure this out   I DID read the help file but it's a little confusing at 10.45pm
    Valued Mentor
    tony.ridley
    Re: Prestress Force
    10-01-2012 06:14 AM in reply to: tony.ridley
    All good answered my own question should have just tried it before asking
    Product Support
    Artur.Kosakowski
    Re: Prestress Force
    10-01-2012 06:16 AM in reply to: tony.ridley
    This is similar to the assembly load case for a cable model. The load from the case indicated in  the selection field is applied on already deformed (by the case 1) structure.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    Artur.Kosakowski
    Re: Prestress Force
    10-01-2012 06:22 AM in reply to: tony.ridley
    Yes,contrary to a cable model the load load from the first load case will influence each of the load cases (the ones that you entered in the selection field) used in the combination. For the cable model the assembly load case is used only one time. In other words if you use it for e.g. two load cases (2 and 3) and then you create combination 2 + 3 the influence of the case 1 will be 'doubled' (1+ 2 + 1 + 3). For the cable model it would be (1 + 2 + 3).
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Mentor
    tony.ridley
    Re: Prestress Force
    10-01-2012 06:37 AM in reply to: Artur.Kosakowski
    For the cable post tension / regular non linear model with NO cable it would be (1+2+3) ??
    Valued Mentor
    tony.ridley
    Re: Prestress Force
    10-01-2012 06:40 AM in reply to: Artur.Kosakowski
    Artur,
    One more thats it.  If I click on the "use first case" check box - but do not enter any cases in the field below the checkbox - is load case 1 used as starting case for ALL cases?
    Product Support
    Artur.Kosakowski
    Re: Prestress Force
    10-01-2012 06:46 AM in reply to: tony.ridley
    if you type 2 and 3 in the field then: (1 + 2) + (1 + 3)
    if you type 2 then (1 + 2) + 3
    if you type 3 then (1 + 3) + 2
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
