• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    athurD
    Accepted Solution
    Pressure under foudation raft???
    295 Views, 9 Replies
    10-05-2012 07:54 PM
    Hi all.
    I is prolem, I think Pressure under foudation raft >0. Why results Pressure Robot <0 ???????
    Please use plain text.
    Valued Mentor
    tony.ridley
    Re: Pressure under foudation raft???
    10-07-2012 11:04 PM in reply to: athurD
    Because it's a reaction?  Under vertical load, a pinned column will have +ve reaction.  So under applied load, a soil will have a +ve reaction too?
    athurD
    10-07-2012 11:52 PM in reply to: tony.ridley
    Thank tony.
    So now I have to do to pressure under the foundation raft <0 ??. This is an image of my model .
    Product Support
    Artur.Kosakowski
    10-08-2012 12:27 AM in reply to: athurD
    As you are supposed to tell in which direction the uplift is possible you should set UZ+ rather than UZ- (at least for a typical building :smileyhappy:).
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    athurD
    10-08-2012 01:54 AM in reply to: Artur.Kosakowski
    Thank Artur.
    i selection U+.
    But why Run it too long, is there a way to make it run faster???
    athurD
    10-08-2012 02:10 AM in reply to: athurD
    Hi. i is prolem.
    How do I know choose U + or U- ??????
    Product Support
    Artur.Kosakowski
    10-08-2012 02:11 AM in reply to: athurD
    You can try to use the multi-threaded solver.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    Artur.Kosakowski
    10-08-2012 02:14 AM in reply to: athurD
    1. Check what is the orientation of the local Z axis of the panel
    2. If you want to allow the panel to move (be uplifted) in the direction of the positive Z axis then you select UZ+. Otherwise UZ-.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    athurD
    10-08-2012 02:16 AM in reply to: Artur.Kosakowski
    Hi.
          "You can try to use the multi-threaded solver."
    Sorry I do not quite understand, can you give me an picture example.
    thank Artur
    Product Support
    Artur.Kosakowski
    10-08-2012 02:57 AM in reply to: athurD
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
