• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    Accepted Solution
    Plate and Shell Deflections - Calculations
    182 Views, 4 Replies
    02-22-2012 07:28 PM
    Hi All
    Robot help says:
    "If properties of materials used during design are identical to those used in a model, then the value of the coefficient D / B > 1.0. This coefficient can be interpreted (mainly for slabs subjected to unidirectional bending) as an elastic deflection multiplier. If different materials are used in a model and calculations (for example, with different classes such as concretes with different Young's modulus or Poisson's ratio), the coefficient value is corrected automatically. It may result in disturbing the the earlier mentioned inequality."
    Please, may have more information about following assertion ?
    1) This coefficient can be interpreted (mainly for slabs subjected to unidirectional bending) as an elastic deflection multiplier:
    • Which is the meaning of "elastic" in this context ?   The coefficient D/B take in account of "element cracking, rheological effects, adherence of calculated reinforcement, etc. and averaged for both directions"  so it is, The intent is to simulate a inherently inelastic situation
    • "rheological effects" means long term delayed strain estimation as in UNI EN 1992-2 5.8.4 -  Creep Annex KK ?
    • "mainly for slabs subjected to unidirectional bending" I think that  for bidirectional slabs should be the same thing
    2) it may result in disturbing the the earlier mentioned inequality. Which is the meaning ?. If in the model I am using i.e.. RCK 25 and in RCK 35 for the calculation off shell deflection D/B may be less than 1 ?
    3) If I am using reduced stiffness of elements like http://forums.autodesk.com/t5/Autodesk-Robot-Structural/EC8-4-3-1-7-Reduced-moment-of-Inertia/td-p/3... the D/B calculation uses reduced or full inertia of elements ?
    Thanks in advance
    Product Support
    Artur.Kosakowski
    Re: Plate and Shell Deflections - Calculations
    02-23-2012 01:01 AM in reply to: GabrieleNovembri1027
    The one you get after running the static analysis of the model.
    •   The coefficient D/B take in account of "element cracking, rheological effects, adherence of calculated reinforcement, etc. and averaged for both directions"  so it is, The intent is to simulate a inherently inelastic situation?
    Correct.
    I'm not sure which effects you mean as I'm don't have what is included in the UNI EN 1992-2 5.8.4 -  Creep Annex KK provisions
    Yes, the scaling as described in the description of the method you refer to is done for all shapes of panels. The main intention of this statement is to inform that the influence of in-plane forces is disregarded.
    I'm not sure if more or larger than 1 for this particular case but theoretically you can use 10MPa concrete in the model and decide on setting e.g. 50MPa concrete with creep coefficient set as 0 in the panel design parameters
    Reduced (for the value of D)
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    02-24-2012 10:33 AM in reply to: Artur.Kosakowski
    Hi Artur,
    You are right. "UNI EN 1992-2 5.8.4 -  Creep Annex KK provisions" is related to bridges instead of buildings.
    Anyway I am looking for a detailed description of the method used by Robot to take into account the concrete creep in the D/B coefficient calculation.
    Product Support
    Artur.Kosakowski
    02-26-2012 11:24 PM in reply to: GabrieleNovembri1027
    Robot uses the formula 7.20 from 7.4.3.(5) of EC2.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    02-26-2012 11:56 PM in reply to: Artur.Kosakowski
    Thanks Artur
