• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    Re: Pile Caps with Robot
    11-19-2012 03:39 AM in reply to: CKDDIZ
    Please use plain text.
    Valued Contributor
    11-19-2012 03:44 AM in reply to: CKDDIZ
    Valued Contributor
    11-19-2012 03:45 AM in reply to: CKDDIZ
    Valued Contributor
    11-19-2012 03:46 AM in reply to: CKDDIZ
    Product Support
    Artur.Kosakowski
    11-19-2012 04:13 AM in reply to: CKDDIZ
    Second model of the pile cap with piles modeled as spring node supports. for moments and shear forces calculation, the reactions of the piles agree also very good. Moments and shear forced on the other hand not so much.
    My understanding is we have already covered this topic.
    The pdf file racomends to use beams as idealized grillage elements in order to find the moments and shear forces for reinforcement design of the pile cap.
    and this is the model from the post 15 whereas yours is similar to the one from post 17. As you can see the later includes bi-directional behavior of the panel which influences the results. These are two different models (compare values of shear forces 1425 vs. 1018 for the same load) and for the book 'approach' you should create a number of beam type models rather than a panel one.
    Artur Kosakowski
    Support Specialist
    Product Support
    Product Support
    Artur.Kosakowski
    11-28-2012 06:52 AM in reply to: Artur.Kosakowski
    Please check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/mat-foundation/td-p/3714038
    Artur Kosakowski
    Support Specialist
    Product Support
    Member
    04-19-2013 10:35 PM in reply to: Jakub.Brozonowicz
    hi i could not open the file please help me
    Member
    04-19-2013 10:39 PM in reply to: Jakub.Brozonowicz
    hi i could not opent this file help me please
